I built a 62t/61x motor, and after running it in for 6 hours I tested my compression. The readings I am getting are 175 on the MAG, and 200 on the PTO.
The engine is running great, and the power is awesome, but the readings are freaking me out, so I pulled the head to inspect the cylinders and domes. There are some slight vertical marks on the PTO Cyl, but nothin abnormal except for the different burn pattern, and there are no scuffs, or signs of seizures.
I would think that at 200psi cranking comp I would for sure be detonating in that cylinder, but the plugs are rich and the ski is not overheating.
Any ideas or help will be appreciated.
Thanks,
Motor type/setup = 82mm Bored and Ported 61x cylinders, Pro-X Pistons, Ported 62T cases, ADA Head w/ 36cc domes, B Pipe, MSD ignition, RAD charging flywheel,
Thanks,
