I just opened my flywheel cover up to pull the the flywheel and stator and found some dark residue behind it. When these are installed with the bendix is there a grease that is used that coulda got flung around in there? I just wanna make sure it's not a crank seal leaking. The residue is very thick and doesn't really have a smell to it.
Does the darker colored piston mean the front cyl. Was running lean? Just don't wanna install this in my ski if it needs seals. Also with the cyl. At TDC should there be a small amount of side to side play between the piston and the cylinder wall?
Sent from my HTC One_M8 using Tapatalk
