- Tuscaloosa, AL
Uh, Tell your teachers you are going to miss Friday and Monday. I doubt they will flunk you.
No need. Foundout I don't start till the end of January.Uh, Tell your teachers you are going to miss Friday and Monday. I doubt they will flunk you.
Sometimes you need to tell a b*tch twice!![]()
Also..Here's what everyone wants to see anyways. I decided to try 180 hop to flips today since my setup wake flips weren't doing so great. I originally just did one for fun, and I was shocked at how far around i got, so I just kept trying them
Video should be visible to anybody:
Try to more flat spin hop than a high hop 180
Would that be a bad idea due to not having a mag pump? I'm already low on veins with the stock pumpYou can gut out your veins on nozzle too.
I'll have to work on flat spin hops, I usually just high hop 180s.. Just curious, why don't you want a high hop?same thing i told him via text, coming in pretty fast too....
Holy crap. That's impressive. I guess i definitely have the power to do what I need!! Thanks for the motivationuse a set up wake.
you have enough motor and pump to do it with that hull.
Here is a few videos of me running a similar set up.
701 @JetManiac port, bpipe, all stock other than that. Stock pump from a sn with a 9/15 xs trim
I originally was doing setup wakes but I'd barely get over halfway, but get good height and a lot of unneeded distance. And then I went to 180 hops and for some reason I was able to concentrate more on looking back and yanking the bars,and had way more rotation.
I think now it's just time to apply it to a wake again. Just gotta figure out the best setup wake for me.
Sent from my SM-G920V using Tapatalk
