- shark river nj
I have a  B pipe set up on my '00 RN with dual cooling through the exhaust manifold - water routed from the front of the head into the bottom of the head pipe and out the top of the head pipe -  the water line goes straight to the pisser with a tee going through a restrictor into the stinger.  I have had this setup for years with no problems at all, until last week.  I had to change out my starter, which led to fixing several other things, which just happen to go bad at the same time.  I tested my ski and had plenty of water coming out both pissers, but after pulling the ski out found the pipe really hot and the silicone elbow had been melted.   I found an obstruction in the brass elbow on the head and removed it.  I figured that would solve the problem, but got the same results, both pissers working but pipe real hot and elbow melted.  My question is does water go into the pipe from the head pipe or just through the stinger.   I could not find any other obstructions while running on a hose, but skis always work in the driveway.   I need to narrow down where the problem is before I buy more elbows.  Thanks, Griggsmars
