In full disclosure im associated with Steve from Fast Elements, and was at the booth for World Finals. I had the Torrent 155 TPE ski in the booth. I am biased as I did my first FW non slide out back flips on this ski at WF Sunday and Monday.
The Torrent is 995, how is that more expensive than the Solas at 1039.48 comparing retail to retail? All Fast Elements items were 15% off or had special pricing until today.
The parting line should not create any issues with the Solas.
The Torrent is 100% American made, corrosion protected Stainless.
Torrent is lighter than the two piece Solas becasue there are three less rings for the flanges, and no long SS bolts required to hold it together.
Tolerance are much tighter. Ask anyone who has assembled either.
How many people on here have really removed their pumps leaving the wear ring and then checked allignment?
Quality of the Stainless on the Thialand build Solas compared to USA made Stainless on the Torrent?
Torrent is available in a setback for the same price as the regular pump.
148 Torrent is availble special order for 149 and 150mm sizes.
155 Torrent is available special order for 156 and 157mm sizes.
Torrent is available special order in colors
OEM quality and hardened driveshafts available from H20 Products for 379 for the setback. Some other manufacturers use soft stainless that wears fast and or tolerances are out to to lunch.
Wear ring discussion is valid for a 148 Solas, but do you have a spare wear ring? If not then youll have to order one. The Torrent can be repaired with a sleeve at any competent machine shop. No shipping wait and most likely quite a bit cheaper. $392.59 for replacement Solas wear ring and no one else has one. Argument is that that could be machined also. This argement does not hold for any set back two pc. The impeller wears on the set back portion not the wear ring. I was baffled at this argement when I bought my first set back two piece and noticed the wear pattern was all in the set back stator section.
I test and tune with impellers with same shims just like most have done for years. I only see a left right issue there with no up down if done properly. That should be minimal unless shoe is off or driveshaft is bent, then thats another issue. The midshaft is keeping it close on right left and up down is the main concern which is taken care of with the shims. I always pull motor to go through entire build once dialed in anyway. I build, tune, then re-check all. If your mid shaft is worn the drive shaft will wear also.
Cooling line locations on the Torrent were moved to accomodate free ride/free style cooling lines and trim set ups.
The Torrent was designed for Free ride/Free style riders. What were the others desinged for?
Torrents in stock, ready for shipment. Is the 148 Solas?
32 safety checks done twice on each Torrent by seperate individuals, not 1 out of 100. How many on each Solas?
Torrent sponsors pro and amateur competitors at WF this year. Did Solas? Evan Krefski and Ryan Doberstein were running them in their comp skis. Ryans was a 155mm. Evan finished 3rd place with a 865 SS gas motor, msd enhancer and a Torrent 148 compared to a bunch of 155s in that field. Johnny Leftly has a 155 in his ski and Bruno Jacob's 3rd place finish at Surf Slam was on a 148. David Oski is on a 155 Torrent and has been competing on a 148 at Naples World Finals. More sponsored riders to come for 2016
Solas is a great pump, but so is Torrent. The choice is yours. Call Jet Maniac, Tiger Craft, True Performance Engineering, Rage Composite Works, Free Form Factory, or Fast Elements in the US for details. Other dealers to come for 2016 and more around the world.
More innovations to come from Torrent soon. There are products in the water now and some are "Game Changers"
I paid attention this week at WF
how did I do?
