Zero Client
BeerrroooOOOT!!!
- Douglasville, GA
Can someone give me a PLUG read? This is a 62t engine, Riva ported 62T cylinder bored to a 717 (701 +1mm). The ski is a 1994 WaveRadier. The pump is STOCK with the STOCK prop.
Carbs are STOCK dual 38s with chokes removed much like a RN Superjet. There on top sits aftermarket OceanPro Flame Arresters.
Engine has an ADA Aftermarket girdled head with 35cc domes.
Pro Tec exhaust pipe.
It also has a Riva/Advent CDI thats very old but similar in timing and spec as an MSD Enhancer.
The run was about 5 minutes of WOT, and 2 minutes of idle/mid throttle. The engine is only reaching 6500 RPMs on my tiny tach.
Am I too rich at WOT? F plug is FRONT.
