Freestyle R50 spooge vs K2
Castor makes alot of sludge if you mix on the oil heavy side.
R50 isn't tcw cert either. I know its good oil but that bugs me. Tc cert is not easy to get from what I've read
CD155MX
Squirrel!!!
Alta Loma, CA
I used to run Skicraft and switched over to R-50 a couple of years ago. I may go back to Skicraft after my current supplies run out. That oil always seemed to burn a bit cleaner.
BruceSki
Formerly Motoman25
Long Island
I moved from 40:1 to a 45:1-50:1 ratio. I noticed a little spooge from the 40:1 as well. Even my weedwacker didn't like it and that calls for 32:1.
I haven't had a problem at the 45-50:1 ratio.
R 50 is a good bit thicker than k2. I have always ran r 50 at 50ish to 1
Yes, R50 is 50 weight oil which of course is pretty thick oil. Alot of dirt bike forums point out the spooge issue and it's suggested that it's due to R50 ' s high flash point. If you're not on the pipe hard with rpm then spooge issue.
PNW
I'm starting to think you just like to say "spooge" :)
I keep a shop rag in my exhaust pipe to keep the R50 "spooge" off my garage floor.
dfw
All the high temp oil will leave a oily exhaust outlet. TCW3 leaves a soft sticky residue and standard JASO or APT-TC leaves a dry sooty residue. I like TCW3 for free ride stand ups. Save the expensive stuff for high performance setups.
