Need some thoughts. Went through this ski & engine, did a new top end (bore and new pistons), leak down tested, rebuilt carb, swapped out stator for known good one, rebuilt CDI by JSS, put a known working regulator/rectifier in and the ski still having issues.
Put it in the water and it runs great for 10 - 15 minutes typically. Sometimes 30 + minutes, sometimes 2 -3 minutes before it bogs and dies. If I am lucky it will idle and I can limp back to dock, let it sit for 15 - 20 minutes and it's back to doing the same exact thing.
Thoughts are it has to be electrical. Start / stop switch possible ? Ground getting hot ? Thoughts appreciated. No idea where to go next.
