Need help and advise on my superjet that I'm having issues with. It's a 62t case with 760 cylinders. I have only ridden the ski twice now and both timea I have taken it out it has run perfect for the first 20 or so minutes, carb it tuned perfect so I have ruled out it being the carb and believe it is electrical. After about 20 minutes of riding it loses its power, the best way I can describe it is its almost like it Rev limits much lower than it should. And if I ease into the throttle around half throttle it runs good. But if I get on the throttle hard or pin it, it just runs horrible and sounds similar to Rev limited but not clean. What I was thinking is it could be either the stator or something to do with the flywheel? Or maybe the coils???? Please let me know what you think it could be. Also I have a flywheel and stator and plate and everything from a 650 would that work if I need it? Thanks
