- Home of the Steelers!
I don't know if this constitutes the start of a build, but the damn thing is finally out of my basement and now in the back of Mazda3 hatchback
Any of you that have been following, know I'm in the midst of a FootRocket build now as well (long story, but I ended up with two aftermarket hulls at about the same time). The key reason I ended up with two hulls and not just one and my wallet light by $1,500 was due to the awesome work of @sinisterjosh209 Josh really came through for me on this hull and made things right.
I believe the Phantom will go together much more quickly than the FootRocket is currently going, as I'm not spending time cleaning resin out of mounting holes, drilling and tapping motor mount plates, aligning and installing pump shoe, affixing hood hooks, installing Watcon hood seal, etc... Point is the Phantom showed up in a much more "ready to build" condition. Now I haven't installed and aligned a pump in it yet, but I suspect it should be straight forward and well within spec. I'll update more pics and details as I start working on the Phantom this weekend.
