snowxr
V watch your daughters V
- Waterford, MI
Art said two weeks ago he is not going to make the billet now. He said he's afraid people will copy it. SO, he's making a cast manifold. We'll see.......
How about turning a $100 adapter for a 760 manifold?
X2 was also curious myself with a pfp 771Hey Tim. Do other applications benefit from this waterbox too or is it just high hp motors? Would this help in a limited set up?
All testing is complete with the v2 free ride exhaust system.View attachment 282250 All testing is complete with the v2 free ride exhaust system.
The power is much more comsistant and pull harder off bottom and mid then the power factor setup that was currently on this DASA 1000.
To answer questions.
If your currently running a small water box or no water box you will see big difference in constancy of power. Jetting will be less sensatice to back pressure changes to to water loading of exhaust track. Aka tail stand, deep landings anytime the boat is deep I. The water the jetting won't go pig rich and require multiple clean out attempts.
It also works real well with power factor pipe.
Cast manifold doesn't work as well.Cast should work just as well and be significantly less expensive.![]()
