- Fresno CA
Have any updates?
You and I both share that flaw.... I always bite off more than I can chew!oh it will! I'm just really good at taking on more projects than I can handle![]()
5.7oz 3k plain weave.Sweet! What kind of carbon did you use?
Cool.5.7oz 3k plain weave.
BTW, How is yours coming along?
here's the bottom and first side layer. I have more done, but this is the latest pic. I filled the bond rail, the area between hood channel and sides, and flattened out the chines (all with cabosil/epoxy mix) to get the carbon to lay better. Didn't quite work out, but it'll be tough, and the inside is rarely seen anyway.I ended up doing 2 layers of carbon. sides @ 45, bottom @ 45, sides @ 90 and bottom @ 90. The corners overlapped 1/2-3/4 of an inch onto the adjacent surface.
![20150707_214050[1].jpg 20150707_214050[1].jpg](https://www.x-h2o.com/data/attachments/196/196417-59952891d3c8d98cdcae6d48b46e9f31.jpg)
![20150706_115947[1].jpg 20150706_115947[1].jpg](https://www.x-h2o.com/data/attachments/196/196419-f2704b6ba5af56801f4bfb82c0116f1b.jpg)
http://www.x-h2o.com/index.php?threads/146362/Where did you buy that pole
lyeah, we will see, could look terrible when it's done.
It would have been like an inch of filler to make it work out, so I'm going to bond the sides in and then fill the gap at the bottom. The floor is solid, it was damn hard to break a 2x0. 5 inch piece of it.Nah! I have high confidence in you! You've got this.
P.S. What are your thoughts of cutting out the "floor area" on the BOB fiberglass pieces and just use your carbon floor and the side pieces from the BOB kit? Might be easier than filling the gap. Just an idea.
