- amarillo ,tx
Yeah easy, v2 bot correct
Rotate it 45 degrees. There are 8 holes to accommodate two different sizes of bolt patterns! Use the four holes that are closer to the center!Guess that hurdle took me out.
Took a while to find the bolts that fit perfect. Turns out I should have bought the skinnier ones that had some slop.![]()
Well if that's the case, grind the heads down (if they hit something) or get the correct 90 degree counter sink bit to make the holes deeper... At least the holes should be in the right place!I will give that a shot but I'm pretty sure those holes have a smaller taper so the actually heads will be to big to sit flush.
Will have to see when I get home.
