Super Jet Case bolt torque confusion
SXIPro
JM781 Big Bore
Hi,
I am having a hard time reading the case bolt torque specs for a 701. It appears there are 8 bolts, but there are 2 sets of torque call outs depending what bolt (or bolts) are being designated, and it's confusing.
Which bolts should be torqued to 11 ft lbs and then to 20 ft lbs, and which ones should be torqued to 17 ft lbs and then 34 ft lbs?
Thanks
schicks
Karma Enforcer
West Michigan
Hi,
Thanks
I believe that the case bolts (8) are 11 then 20 ft lbs and the bed plate bolts are the 17 then 34 ft lbs.
