Hi everyone,
Greetings from up north, more exactly northern Europe - Finland.
Not the best place to live if you love skis.
Parts list for the new setup (UPDATE 2021)
Rickter XFS Ninja Competition 2014
Hull (Rickter XFS Ninja Competition Lightweight 32kg)
-OEM handle pole spring
-Rickter XFS Ninja plate short
-Rickter Ninja intake grate
-Blowsion blue billet h-pole
-Blowsion rise bars 52,5mm
-Blowsion custom turbulator chinpad
-Blowsion blue steering kit OVP
-RRP handlebar extensions
-ODI/Ruffian 130mm blue grips
-Blowsion throttle lever
-H20 trim lever
-Blowsion lightweight billet h-pole bolt
-Blowsion blue washers & wateroutlets
-Rickter scrupper valve
-Lithium battery 915gr
-Blowsion billet battery tray
-Blowsion battery tray riser
-RRP billet strap hooks
Pump:
-Skat-trak mag 155 billet setback pump
-RRP 155 trimkit
-RRP 155 pump shoe
-Skat-trak extended driveshaft
-Skat trak 9/15 impeller
-Cold Fusion midshaft spacer
Engine:
-TPE 964
-ATP Flame TS2 Total loss ignition (MSD TL as a backup)
-ATP electrical box
-ATP Flywheel
-Cold fusion engine mounts
-Novi tech 48
-DASA dual billet intake manifold
-V-Force 3 reed's
-Tau Ceti air forced tornado filters
-RRP Carbon exhaust
-RRP waterbox
-Blowsion Black Mamba exhaust hose
-Kart tank
-Cold fusion tank holder carbonfiber
-Blowsion/Jetworks flow control valve
-Cold Fusion fuel filters
-Mikuni Primer kit
-ATP driveline couplers
Cheers
-H20 trim lever
Pump:
-RRP 155 trimkit
-RRP 155 pump shoe
Engine:
-TPE 964
-ATP electrical box
-ATP Flywheel
-Novi tech 48
-V-Force 3 reed's
-RRP Carbon exhaust
-RRP waterbox
-Kart tank
-Mikuni Primer kit
Cheers
