- detroit MI
god thats a pretty hull
Fixed it for you...god thats a pretty hull
Some progress today watcon hood seal is mounted.
Only problem it seemes pretty big and hood sites realy high now, does some one know if it Can bee cranked down with a racet strap ?
Also Got the pole/hood hookes/and loocking system on
Couple off guys here have asked about B pipe setup, dont think its possibel with a stock waterbox.
Maybe it Can ve used in the PFP waterbox position.
Stefan,
I used a Watcon on my Freak build and it made the hood setup high as well. Either ratchet strap it down for a day or cut a vertical groove along the entire length of the hood seal so that the hood lip can set down into the hood seal foam. I cut mine and it worked well for 2 years.
Yes I was just confirming that they don't need them anymore , with breather tubes in pole and the way the liner is made u should be fine even with 1200, just looking at the new way hood liners are made that's all I was just curious........Idont think it needes breather tubes, if you look att it takes in air att the back. Any water intrution will have too run up hill.
Cool you got a pool and pump deal ? Where a you located ?Watching your build with great interest. Looks like it's going good. I've ordered same hull but went for orange.
Yes it is veines a sharpende, too help flow.Ski looks great, but those veins on that pump are SUPER thick. Is that the Maxx pump?
SM
