Hello,
Although my engine is finally running well, I don't trust my hull.. The tray has been filling up with water since I got it and i see it pouring water out the exhaust and scupper rings when I tilt it on the trailer.. (scupper is blocked off from the engine comp.)
I am pretty sure there is no foam in there since each time I unload the ski the tray floats well above the water for the first couple of minutes, then after riding a bit it is a couple centimeters underwater.
Plus one time I flipped it and it almost sank. The rear half of the hull was underwater with the engine compartment sticking above the water. Thankfully it has a bilge pump which saved it while i was swimming to shore dragging the ski with me.
I've been searching for a bit but found a bunch of threads on refoaming sj's. I know it's the same principles, but I don't want to cut up my tray in places I shouldn't have to.
The only reason I decided I'm going to invest in the hull instead of the engine is the fear of sinking my ski in the surf. I have a surf hull and I haven't been in the surf yet because of this issue. I was going to buy some performance parts but In my opinion if the hull isn't good, it's not worth it.
If anyone has done this to their Bob hull and can post a couple of pictures to help me out would be awesome!
Thanks!
Thanks!
