SXIPro
JM781 Big Bore
- Here on the 'X' mostly
Yeah, so I've been having start issues and have concluded it's my stator and more than likely the pulser coil. No biggee, right? Well I pull the flywheel cover and the inside of the cover is loaded with gas, oil, and most worrisome, a pretty decent collection of metal shavings.
Plus when I pulled the cover about 2-3 tablespoons of goo poured out)
So, I am guessing my crank seal is gone. But where did these shavings come from?
Also my compression seems low. It is dead even but low. However I did test it dead cold (Wiseco pistons).
Can a blown crank seal lead to low compression or are the low readings more likely from a cold motor?
