Hello,
On Saturday I'm pretty sure I almost sunk my ski.
I went after a yacht wake and turned out to be the biggest boat wake I went for till now haha I tried a 180 off of it but somehow ended up underwater with the ski on top of me. when I popped up the ski was upside down and taking in water. I pulled the lanyard but it came off my hands instead. The ski was pretty heavy to turn over, but when I did the ski was half underwater, but the rear end was under. The engine shut off and wouldn't start so I started swimming and dragging the ski to shore. By the time I got to the shore the bildge pump pumped all the water out from the engine bay. But the tray was full of water. I rode it for a bit when I got it started to make sure everything was ok and went home.
The main reason I'm asking if I should have my hull and tray redone because I'm pretty sure there isn't foam in there, or it took on water. Plus there are pole vent holes which are not very sealed which i am not using since I have a umi pole on my setup. Thinking about sealing them off. I would not want my ski to go down.
When I tilt the trailer up to let it drain I see water coming out of the rear of the ski where the turf ends in the back, and from the rear tow holes ha can't remember the name now.
So basically I would have to refoam, touchup the hull in the rear, seal off the pole vents, repaint and returf.
Does anyone have an estimate on how much this would cost to do?
