WaveDemon
Not Dead - Notable Member
- Hell, Florida
I've got some 25mm underpad that will need to be trimmed and shaped. I'm guessing a few passes with a razor blade should cut it but what about shaping? sand by hand or power tools?. I have a sanding disc that seems to be the perfect size to cut down the area for the stern eye, should I use that? I'm sure I'll need to shape the area in the holds too.
the hardest part will be in the front. I've got a 1/2 in thick plate that my foot strap will mount to. I'm thinking I should cut the pad out in that area and replace it with either a shaved down thick pad or use the thinner underpad that will come with my turf kit. Maybe just tuf over it?
Thanks for any advice. :biggthumpup:
