I am running a Yamaha 701, with a B pipe, stock carbs/intake and a ADA head with 185PSI in either jug. The issue i am running into is that spark plug in my front cylinder(closest to the nose), continues to bend after a few rides. The part that is bending is just the threadded metal at the top in which your plug wires connect to. Unfortunatly around my area I am unable to find solid top NGK plugs. Currently I am running BR8ES.
From reading on the internet, this bending is an effect of running too hot for the plug. Is this something that other people have had happen? I had this issue with my 650 as well.
My next step is to switch that cylinder to BR9ES in hopes to run a bit cooler.
Your thoughts are greatly appreciated.
