Should i repair this?
after i fixed some of these chips/marks on my superjet i painted it with Rust-olium enamel gloss white out of a spray can, it matched perfectly on my hull. that being said i would definatly recommend testing the color on something else first to see if it matches.
So what exact product did u use to repair this? You end up gettin that smooth finish again like it comes brand new?
I not an expert on this subject but what i did (because its not structural) i used West System epoxy resin and hardener mixed them up added some thickener also west systems product. So i prepped it, applied it, then after i got it all sanded down and smooth (might take more then one application and sand to get it perfectly smooth) i used the rust-oleum enamel gloss white paint. it turned out really good if you where running your hand on the paint you could tell where the paint changed from OEM to the spray can, but for me color was bang on.
if this isnt right some plse correct me, but this is what i did and it has worked so far
