849tigerbotkv1
formerly ihate5mphzone
- where i can ride 2stroke
Did nuklear ever drill holes on his hood to make a hood vents?Definitely saw hood vents too.say what you want but you absolutely need hood.vents to get ultimate power. First hull I ever built had a bone stock sxr engine in it has.the hood had no vents only.vented through rrp.the seal on hood was so tight with hull it would flex took me a few runs to figure out the issue when the bilge fittin started whistlin I knew it needed more air. Night and day difference after I installed 2 hood vents
Same happened to nuklear on his aquabot
Sent from my SCH-I605 using Tapatalk 2
