My Full Specs have fuel pump block off plates so I'am interested to see or hear how you guys are mounting remote fuel pumps in aftermarket hulls. Also on the pulse lines run one and cap the other off @ the case? What do you think about putting pumps back on the carbs and run it that way, I'am not racing just some fiat water and have access to pumps? Searching I only found 1 image so far and a Blowsion fiber mounting plate I don't really get.
My ides so far are to sand witch a plate below the battery box with a 90 deg bend and mount the pump up high to this plate or run a metal battery box with a mounting plate welded to it and rising up and mount the pump on to that.
Thanks in advance for the help!
