sxr pump issue
montreal
just rebuilt my sxr 800 pump this winter,change bearing and impellor shaft and prop,put a skat 5mm cut back,when i put the pump back im having trouble to put it back in place i have to tap in the back whit a piece of woods to get it in is place.is this normal?
550/440
Maybe I'll get it all the way around NEXT time....
Arizona!
Your hull may have "relaxed" a little while the pump was out. I've experienced this with both my SX and my STX - they use the same pumps as the SXR.
PNW
mine does that too. Did you grease the end of the driveshaft splines? I found that too much grease actually builds pressure when pressed into prop and pushes pump backward off the shaft.
