This was a complete overhaul, all seals and shaft were in grease. The outer seals get washed and wear much faster than inners do even with water present.Um you know having the ski in the water helps cool your midshaft and pump bearings, right...? I'd be surprised if the bearings and seals could last 30 minutes straight, let alone 3 hours of running out of the water...
