- Jackson MI
You should post some pictures of it!
			couple pics of the bonding
yeah... tem, I'm happy with it. forgot to put the inserts for the pump in but i'm gonna line it up then drill and rout out a section to put inserts in or just glass in some SS plates.
What about if you have less clamps you compensate with flat bars of metal to disperse the pressure laterally ? Wouldn't that also prevent the slight high n low areas that can be seen once it's painted ? ( clamp pressure areas).Looks awesome Nick! Glad to see this hull come together! Looks like you needed a few more clamps
