JetManiac's Engine Rebuild Supershop
Everything you need to build, rebuild, or make changes to your watercraft motor from the crank up!
We stock rebuild parts from OEM and most a/m suppliers like ProX, Wiseco, DASA, SBT, WSM, PHP, and Xscream for stock motors and custom freestyle motors. We specialize in Yamaha based freestyle motors and rebuild parts, but also can help with your Kawasaki, Sea Doo, and other brands rebuilds.
Pro X cast pistons
Pro X pistons are precision machined on the latest, state of the art CNC equipment. Pro X uses same low-expansion, low-friction piston alloy is used as is used by all major Japanese engine manufacturers. Pro X Piston Kits are Japanese made and a direct replacement piston fit and quality.
Pro-X Piston Kits are complete with Riken Japanese piston rings, wrist pin, and circlips. Ready to install!
(Wrist pin bearings are not included with any watercraft brand of pistons.)
Yamaha 701 Sizes:
81mm (Stock bore Yamaha 701 and 1100)
81.25mm
81.5 (710cc)
82 (718cc)
82.5 (726cc)
83mm (735cc)
Yamaha 760 Sizes:
84mm (Stock bore Yamaha 760 and 1200nonPV)
84.25mm
84.5mm (763cc)
85mm (771)
85.5mm (781)
ProX Yamaha piston kits $149. sale 109.90/kit
(piston, piston rings, wrist pin, and circlips)
(also available for Kawasaki, Polaris, SeaDoo, and Tigershark)
Wossner forged pistons
Wossner pistons are high quality and forged in Germany.
Yamaha 701 sizes for 81 to 83.5mm in stock.
Yamaha 760 sizes for 84 to 86mm in stock.
Kawi pistons available also.
Wossner piston kits $159. sale 114.90/kit
Wiseco pistons
Precision Forged pistons, state of the art CNC finishing, ArmorGlide® skirt coating, complex dome profiles, and optimized shirt shapes are only a few features that make Wiseco forged pistons the best available.
-Contact us for current pricing for your ski.
DASA pistons
Sizes 89, 89.5, 94, 94.6, 95mm in stock.
WSM pistons
Rebuilt Crankshafts
Yamaha rebuilt OEM crankshaft for 650/701/760 $349.80
*No core required
OEM Yamaha Crankshaft has been rebuilt by SBT with all NEW crank bearings inner seals and NEW connecting rods, then trued and welded to better than OEM specifications.
- 1 year sbt warranty on manufacturer defects
- We have now sold over 1000 of these cranks with great reliability even in high performance, large bore motors.
Crank bearings and Rods
Replacement front, rear, and middle crank bearings
ProX rod kits (replacement rod, upper/lower rod bearings)
Gaskets
Individual gaskets, crank seals and custom JM gasket kits
JetManiac sells high quality US made gaskets using materials that meet or exceed factory specs.
We have individual gaskets or complete gasket kits for your build or rebuild.
Exhaust manifold and headpipe gaskets
Cylinder Base gaskets
Yamaha 650/701/760 cylinder base gasket 7.95
Stock thickness 0.020”
Thinner 0.010" thickness available
Thicker Yamaha 650/701/760 cylinder base gasket (3 layer- fiber/metal/fiber) 18.90
(available in 0.030, 0.040, 0.050, and 0.060”)
DASA cylinder base gasket
TPE cylinder base gasket
Intake and carb base gaskets
61x intake to reed plate/upper intake gasket 5.95
61x reed plate to cases/lower outline intake gasket 5.95
61x reed cage to reed plate gasket 2.89
61x intake side gasket kit 21.90
Flywheel cover gaskets
Flywheel cover gasket 12.95
62t cases/61x cylinder 701 SuperJet/Blaster motor custom gasket kit -dual 38 carbs, bpipe exhaust, Oring head $56.95 sale $52.95
62t/64x cases/62t cylinder 701/760 SuperJet/Blaster motor custom gasket kit -oem dual 44 carbs, bpipe exhaust, Oring head $56.95 sale $52.95
61x/61x Yamaha 701 gasket kit for motor with oring head and Factory bpipe exhaust $49.95
Custom gasket kits:
Tell us your setup and we make a custom gasket kit for you.
Which cases, cylinder, head, exhaust, intake, and carb(s) do you have? Get the correct gaskets for your setup.
Crank seals Case sealer
Yamaha OEM crank seals- set of all 3 seals $63.95 Sale 39.80
* Fits Yamaha 650, 701, 760, 1100, 1200nonpv
XS1200 Yamaha OEM crank seal set $90.95 Sale 59.90
* Fits XS1200 and Yamaha 800 motors, set of all 3 seals
Threebond 1211 HiTemp silicone sealer 23.95
* Japanese silicone liquid gasket, OEM spec
Threebond 1184 $19.95
* Same as Hondabond 4. Yamabond 4, Kawasaki Case Sealant 4 / great for sealing uneven surfaces, OEM spec
Yamaha OEM brass case pulse nipple 5.95
Blowsion 62t engine storage/blockoff plates with hardware 49.95
Blowsion 62t engine HD thick storage/blockoff plates with hardware
Pro X cast pistons
Yamaha 701 Sizes:
81.25mm
81.5 (710cc)
82 (718cc)
82.5 (726cc)
83mm (735cc)
Yamaha 760 Sizes:
84.25mm
84.5mm (763cc)
85mm (771)
85.5mm (781)
Wiseco pistons
DASA pistons
WSM pistons
Rebuilt Crankshafts
*No core required
Gaskets
Custom gasket kits:
