octane has nothing to do with it. if you only knew. i run piss yellow turpintine smelling 3 year old gas with bugs floating around in it, in some of my motors that have 205 or 210 comp and full race porting. i dont just pin it for 1/4 mile runs but i dont not WFO it either and they never blow up or show signs of detonation. i dont waste old gas and my local shop actually saves me all the old gas from skis he services. free gas for the weekend : )=
Ive run old gas in the past, 2 year old or so left over, mixed maybe almost one gallon into each 5 gallon container with 4 freash gallons, went ok but i dont keep it around now, use what i buy in a resonable time frame. Free gas is hard to turn down though
Little story worth mentioning maybe. Late model Van comes in for a drivability concern, PO304 misfire DTC, runs like poop, backfiring in the intake, resembles a broken valve spring, this paticular engine does that once in a blue moon, its still under factory warranty so the valve covers are removed for a visual inspection. Find #4 cylinder valve spring is ok but the pushrod is bent and out of place?, install a new pushrod and rocker shaft assembly and restart it, same issue again, puill the valve covers back off and the push rods bent again and has broken the foot of the rocker WTF. Tear the cylinder heads off, fuel that spills out the fuel rail stinks. Inspect cam and roller lifters both look good but the engine cylinder walls have this funny dry parched look. Inspect the cylinder #4 valves find the intake or exhaust i forget which is closed and will not come out of the valve guide, its malled in there. Took a fuel sample to send out for tesing, smalls real bad, stinky, the factory is involved now. Pull the pistons and the rings are all stuck in the groves, cylinders dry and parched and scuffed. Everything the fuel touched that was internally lubricated or not was damaged. The porter who dropped the customer off said they lived on a large ranch, later We found out they were fueling out of their own tank. Long story short, this was not a warrantable repair, coverage was declined. The engine, fuel rail, fuel injectors, fuel pump and fuel tank all had to be replaced costing the customer $8000 to 10,000 dollars. I think they got their car insurance involved after manufacturer declined repair. Old fuel may work but when it doesnt its flipping expensive, not sure its worth messing with for the average Joe
