Philip Clemmons
Owner, P&P Performance
- Richmond, Va
I don't have enough info on you, your ski, or riding style to make a call there. I can tell you I've seen similar numbers on "a few" pump gas boats.
Your dilemma is twofold.......you're not sure that the reading is accurate (maybe due to oil), but the motor isn't broken in either. It may go up or down depending.
If it were in my shop, I'd probably run it a while on the hose and recheck it. I'd make a call from there. Borrowing a friends gauge for comparison wouldn't hurt either.
Remember everyone's circumstances are different, as are there measuring methods. Battery strength, throttle opening, and opposing plug in or out can all affect readings. No one can accurately diagnose over the Internet, even with the best intentions.
Proceed at your own risk.
