New Engine Rebuild Parts: Rebuilt Cranks, ProX and Wiseco pistons, Gaskets, Crank Seals, etc
JetManiac
Stoked
orlando
JetManiac's Engine Rebuild Supershop
Everything you need to build, rebuild, or make changes to your watercraft motor from the crank up!
We stock rebuild parts from OEM and most a/m suppliers like ProX, Wiseco, DASA, SBT, WSM, PHP, and Xscream for stock motors and custom freestyle motors. We specialize in Yamaha based freestyle motors and rebuild parts, but also can help with your Kawasaki, Sea Doo, and other brands rebuilds.
Pro X cast pistons
Pro X pistons are precision machined on the latest, state of the art CNC equipment. Pro X uses same low-expansion, low-friction piston alloy is used as is used by all major Japanese engine manufacturers. Pro X Piston Kits are Japanese made and a direct replacement piston fit and quality.
Pro-X Piston Kits are complete with Riken Japanese piston rings, wrist pin, and circlips. Ready to install!
(Wrist pin bearings are not included with any watercraft brand of pistons.)
Yamaha 701 Sizes:
81mm (Stock bore Yamaha 701 and 1100)
81.25mm
81.5 (710cc)
82 (718cc)
82.5 (726cc)
83mm (735cc)
Yamaha 760 Sizes:
84mm (Stock bore Yamaha 760 and 1200nonPV)
84.25mm
84.5mm (763cc)
85mm (771)
85.5mm (781)
ProX Yamaha piston kits $149. sale 104.90/kit
(piston, piston rings, wrist pin, and circlips)
(also available for Kawasaki, Polaris, SeaDoo, and Tigershark)
Wossner forged pistons
Wossner pistons are high quality and forged in Germany.
Yamaha 701 sizes for 81 to 83.5mm in stock.
Yamaha 760 sizes for 84 to 86mm in stock.
Kawi pistons available also.
Wossner piston kits $159. sale 109.90/kit
Wiseco pistons
Precision Forged pistons, state of the art CNC finishing, ArmorGlide® skirt coating, complex dome profiles, and optimized shirt shapes are only a few features that make Wiseco forged pistons the best available.
-Contact us for current pricing for your ski.
DASA pistons
Sizes 89, 89.5, 94, 94.6, 95mm in stock.
WSM pistons
Rebuilt Crankshafts
Yamaha rebuilt OEM crankshaft for 650/701/760 $309.80
(with a core returned)
OEM Yamaha Crankshaft has been rebuilt by SBT with all NEW crank bearings inner seals and NEW connecting rods, then trued and welded to better than OEM specifications.
-Comes with a 1 year no fault warranty (on a crank, wow!)
-We have now sold over 1000 of these cranks with great reliability even in high performance, large bore motors.
*No core option $69. on Yamaha rebuilt cranks, JetManiac has you covered which means a faster and less hassle build.
Rebuilt Cranks also available for most other brands.
Yamaha 1100/1200 nonPV rebuilt cranks 489.
Kawi 650 299.
Kawi 750/800 399.
Crank bearings and Rods
Replacement front, rear, and middle crank bearings
ProX rod kits (replacement rod, upper/lower rod bearings)
Gaskets
Individual gaskets, crank seals and custom JM gasket kits
JetManiac sells high quality US made gaskets using materials that meet or exceed factory specs.
We have individual gaskets or complete gasket kits for your build or rebuild.
Exhaust manifold and headpipe gaskets
Cylinder Base gaskets
Yamaha 650/701/760 cylinder base gasket 7.95
Stock thickness 0.020”
Thinner 0.010" thickness available
Thicker Yamaha 650/701/760 cylinder base gasket (3 layer- fiber/metal/fiber) 18.90
(available in 0.030, 0.040, 0.050, and 0.060”)
DASA cylinder base gasket
TPE cylinder base gasket
Intake and carb base gaskets
61x intake to reed plate/upper intake gasket 5.95
61x reed plate to cases/lower outline intake gasket 5.95
61x reed cage to reed plate gasket 2.89
61x intake side gasket kit 21.90
Flywheel cover gaskets
Flywheel cover gasket 12.95
62t cases/61x cylinder 701 SuperJet/Blaster motor custom gasket kit -dual 38 carbs, bpipe exhaust, Oring head $56.95 sale $52.95
62t/64x cases/62t cylinder 701/760 SuperJet/Blaster motor custom gasket kit -oem dual 44 carbs, bpipe exhaust, Oring head $56.95 sale $52.95
61x/61x Yamaha 701 gasket kit for motor with oring head and Factory bpipe exhaust $49.95
Custom gasket kits:
Tell us your setup and we make a custom gasket kit for you.
Which cases, cylinder, head, exhaust, intake, and carb(s) do you have? Get the correct gaskets for your setup.
Crank seals Case sealer
Yamaha OEM crank seals- set of all 3 seals $63.95 Sale 39.80
* Fits Yamaha 650, 701, 760, 1100, 1200nonpv
XS1200 Yamaha OEM crank seal set $90.95 Sale 59.90
* Fits XS1200 and Yamaha 800 motors, set of all 3 seals
Threebond 1211 HiTemp silicone sealer 23.95
* Japanese silicone liquid gasket, OEM spec
Threebond 1184 $19.95
* Same as Hondabond 4. Yamabond 4, Kawasaki Case Sealant 4 / great for sealing uneven surfaces, OEM spec
Yamaha OEM brass case pulse nipple 5.95
Blowsion 62t engine storage/blockoff plates with hardware 49.95
Blowsion 62t engine HD thick storage/blockoff plates with hardware
JetManiac
Stoked
orlando
Cylinder Head Orings kits
ADA 701/760 cylinder head complete Orings kit $29.95 sale 23.95
Blowsion 701/760 cylinder head Orings kit 19.90
DASA head Orings kit 29.
ET tech head Orings kit 19.90
ET tech cylinder base gasket 23.
Kommander Kawi head Orings kit
PHP 898/1000+ head Orings kit 19.90
ProTec cast 1 piece head Orings kit 8.90
ProTec billet 2 piece head Orings kit 19.
RIVA 701/760 head Orings kit 22.90
XS 900/1000 head Orings kit 19.90
XS C1-C3 1200 head Orings kit 19.90
XS C4-C5 1200 head Orings kit 19.90
Orings for Intake manifolds
PHP
speed plate to intake Oring $2.95
Boyesen speed plate to intake Oring $2.95
Boyesen reed cage to intake Oring $2.95
DASA speed plate to intake Oring $2.95
DASA VF2 cage to intake Oring $2.95
Rhaas dual 44 speed plate to intake Oring $2.95
Rhaas dual 38 speed plate to intake Oring $2.95
XS1200 intake/spacer Orings kit
XS1200 exhaust mani Orings kit
RIVA red pipe headpipe gasket 11.90
R&D intake mani gasket 7.
TPE head Oring kits
TPE custom cylinder base gaskets
DASA rebuild parts
Riken/OEM replacement rings
PV gaskets and PV rebuild parts
Coupler Removal/Install Tools
index.php
3 finger Yamaha motor/midshaft OEM 650/701 Coupler install/removal tool 27.95
5 finger Yamaha motor/midshaft OEM 760/1100/1200 Coupler install/removal tool 27.95
Kawi sized coupler install/removal tool 39.95
(fits ADA, RRP, Epic, and OEM Kawasaki couplers)
Flywheel lock tool -Cold Fusion
Hey mate,
I will soon be ordering a rebuild kit for my blaster 1 701 motor from you. Is there a link you can send me to purchase parts or how can i go about it? I am based in New Zealand. I already have an exisiting paypal account also
cheers
Aaron.
I don't think you can PM if you have less than 5 posts.
If you have less than 5 posts go to some build pages and say, wow, that's a sick build .
Then PM jetmaniac as above.
Jetmaniac is super fast, as soon as you paypal him the coin he ships it. Same day usually. Best kept secret in builds is to get your gear from Jetmaniac.
Have only ever used jetmaniac in the past via my mate Simon who lives in the same town as myself. used one of jetmaniac's cranks last time and was very pleased with it plus price! and pistons but have one siezed motor which is ripped apart on the garage floor at the moment haha so .... rebuild here i come once again
