mike b
- California
Friend and I are tuning his 701 square with dual carbs. Motor and all is from raider701. Put a stock superjet exhaust on engine and it fired right up. Would idle nice but once you would give it gas it would bog and want to die or even die sometimes..Too Rich?
Started tuning the low adjustments to lean out the engine but same problem. So i went to adjustment for low speed again but richened it a bit more than how it came out of the waveraider but it wanted to rev a bit so shut it down before it ran away or something. Came out the waveraider with 6/8 for low speed which i thought was close to what the superjet dual 701 usually runs. Any ideas on why its not running right. Ive done this swap before and i just leaned the motor to 5/8 on low speed and worked fine. Btw motor worked great in waveraider and carbs are bringing in fuel. already checked diaphram and thats in good shape too so i know it is getting enough gas into the motor
