can you take a few pictures of your trim set up for me??
How much for the poles? Where did you get them?
I eliminated the Trim for the time being, the cone I was using snapped so there goes that haha. But honestly, all you have to do is run a cable inside one of the (empty)cooling lines out the back and run the cable right up the pole to a finger throttle
yeah I have a 750 that ive done this too, I run dual 500's bilges so i removed the stock bilge, used that cooling line for my trim cable then sealed it up, problem is I cant seem to get enough throw on it because when the pump is under pressure it makes it almost impossible to use... haha plus i keep snapping cables! (im using the terry cable) :banghead::banghead::banghead:
Ah i see what your sayin exactly, I had a really good cable for mine but i think after i broke the pump nozzle i just cut the cable up haha, but it was a great setup. my buddy has one still setup ill try to get exact spec's from him.
Well theyre sending me a new one so ill try this one. A lot of people recommend this cable on the forum as a good replacement inside of buying the pricy xmetal Ot etc. If it snaps again ill look into something else stronger.
Sent from my VS840 4G using Xparent BlueTapatalk 2
