91 superjet stock carb setup
I just finished dropping the engine back in the ski. The tape that I had marking the fuel lines fell off. The carb has 2 inputs. Which is intake and return? Top or bottom?
Tks
Jeff
on my carb there is three inputs.. and they go Top goes to the top of the gas tank vent, Middle goes to purge, and bottom gas in line. There should be arrows on the top and bottom inputs showing the flow
Mike W
Infidel
North Florida
If i remember correctly, the top one is the return (fuel out to the tank) and the bottom is in from the filter. The one on the fuel pump which is off by itself goes to the top of the intake.
Maybe this pic will help:
Shonuff
I've got the glow
Memphis
Bottom one is in from petcock, top one is back to gas tank, middle one is pulse line to/from crank case.
:woot:
