G
Goose
I took a set of 62t760 cylinders and decked the bottom of them to lower the port timing to get it closer to 61x port timing and im also gonna do the sport port porting to it and run 180psi compression on a set of 62t cases.do you think i should use the dual 38s or go to a single 46 or dual 44s for freestyle.also will this be a decent reliable motor,and im running a b pipe
thanks
thanks
