"To increase the rpm limit, turn the potentiometer shaft clockwise. If you turn the shaft until it stops, the rev limit will be set at 9,000 rpm. To decrease the rpm limit, turn the shaft counterclockwise. If you turn the shaft until it stops, the rev limit will be set at 5,500 rpm"
