Other hole in bpipe manifold bolt area
motozachl
uPsiDeDoWn
JAX
Help!!!! :mad:
Accidentally drilled too deep while tapping the manifold. Is this area below where water flows or exhaust?? Will just putting the bolt in be fine?
OCD Solutions
Rentz, GA
Little bit of JB weld should do the trick plus the bolt will seal it as well. The real trick will be using something that will seal the threads and allow it to be removed in the future if needed.
