- Medina, Ohio
Will these work together?
Everything will remain stock.
How far can I advance the timing?
Which way and how far to turn the stator plate?
Can I dry out the oem exhaust?
Timing can be advanced a few degrees in either direction from stock. Once you bolt the stator up to the cases, you see three timing marks. Middle is stock, the one furthest from the middle is advanced from stock (you would want halfway between stock and that mark).
Thanks Matt. The stator and flywheel were both factory installed on the 61x 700 single carb motor in the pics. So I should be able to use the 2002 SJ electrics with the stator already installed?
What's up with this? I only have one set of timing marks. 61x/61x
One on the stator, three on the cases.
Point is, they are there and absolutely usable for (easy) timing. That's why they are there. I'd never remember which way the motor spins, my brain is made of swiss cheese.
The marks made it easy for me, as the advance mark is noticeably further from the center than the other one.
