OCD Solutions
- Rentz, GA
It's more of a reassembly than a build but I figured I'd give it it's own thread. I do have some paint change plans for the distant future but for now I just want to build it and ride it.
I wasn't planning on ever parting with my ES hull but I showed the 'Pro" sale thread to my wife and she convinced me that for the right price, it was a no brainer. I made an offer and 1900 miles, 6 states and 32 hours of driving later, it was in my garage.
Misc Specs:
Trinity Matrix Pro Hull (-2")
Bare Hull weight: 83 lbs
Hood weight: 9.8 lbs
Hull with hood, hood seal, turf and dual pump dumps: 104.5lbs
Assembled dry weight: xxx lbs
Ready to Ride weight: xxx lbs
Compression: 195 lbs
Hull;
2011 Trinity Composites Matrix "Pro" hull,
Trinity Footholds
Dual Thrust Scuppers mounted in the pump area
ATP Performance Waterbox
Stock Fuel tank with Wamiltons Billet Internal fill
Thrust Innovations Billet External Fill
Engine and electrics;
X-Scream SS846 Billet cylinder kit (annodized black) (195 psi)
OEM Trued and Welded crank
64U Cases ported and epoxied by X-Scream
Boyesen/Full Spectrum Extreme Velocity Intake
Dual Mikuni 46's modded by X-Scream and painted black
B-Pipe modded by X-Scream, (limited chamber) and ceramic coated by airborne Coatings in Denver, NC
Prok Filters with Outwears
JSS 62T Stator with JSS Stainless Laser cut washers
JSS Coil
JSS Battery and Starter Leads
TBM Lightweight Charging Flywheel
Cold Fusion Billet Flywheel cover
Billet UMI lightweight couplers
ATP E.P.I.C. programmable ignition Module
Deka ETX-9 AGM battery
Custom aluminum mini Battery box
GP800 Motor Mounts with Kenney Keepers
Pump and handling;
Skat-Trak 144mm Magnum Setback Pump
Skat Extended setback driveshaft
14/19 Skat C75 Impeller
Skat Nose cone
Worx 201 Intake
Stock Superjet D-cut rideplate
Sato Engineering Reduction and trim setup
New OEM stainless wear ring
Steering and handpole;
RRP Handpole with black annodized tubes
RRP Dual breather bracket
RRP Chinpad support bracket
RRP Pole Spring mount
Stock modded pole spring
UMI Sealed bearing steering system
X-Metal -2.5" Turnplate
X_Metal Straightbars
Wamiltons RRP Chinpad
JSS Start/Stop switch
ODI Grips
Wamiltons Finger throttle
Kawi 650sx Throttle cable
Hot Products Adjustable Throttle Drum
Misc Specs:
Hull;
Trinity Footholds
JSS Coil
Pump and handling;
Skat Nose cone
Worx 201 Intake
ODI Grips
