subhard
TITS OR GTFO
- anchorage ak
Do you run a bilge? They don't leak and move a lot of water. Even with t/l I don't understand why guys aren't running them.
Just curious what needed to be done to get it to fit ?
Thanks for the reply ! yea just wasn't sure if there was a tube from the bulkhead or if it was just open under the tray ,also wasn't sure if there was a tube if it was the correct diameter.looks like a great "personal touch " with great function to boot .i definitely get water in my hull when doing stabs or rolls (standard) it sounds like a good way to get rid of water fast ....I have no foam in it so it was as simple as cut a hole just smaller than the diameter of the scupper, put some silicone on and around it and pound it in the hull![]()
My guess is just doing tricks in general. I've had quite a few failed flips and have been under the ski for a while keeping the ski running. Then when I'm riding away I can feel the extra weight of the water, but the scupper dumps it very fast. I did a silly long fountain a couple days ago just to see how much water I could take on. It did take on water, but no more than my last two hulls would and the scupper dumped it fast and it didn't swamp out. I use a single bilge for swamped out in the lake emergencies and haven't had to use it yet. I have zero experience with the duck bills though. Maybe others will chime in?
awesome flips man! wish my form looked like that.
any barrel roll vids?
You're still using a stock 155 pump? That's what you're testing the TBM stuffer with?
