Surfriding WOT ski is acting very weird. has no power then goes full speed then looses power
JT_Freeride
John Tetenes @Jtetenes
Long Island
Did anyone suggest the start stop switch. In past few weeks I've come across about 8 skis where the S/S switch was the problem the whole time. If the ski is doing the problem where is wont start disconnect the cables for the switch and jump it with a wire. And another suggestion is the selector valve maybe clogged its worth trying I had that problem with mine it was a little gunked up and would cause the ski to starve at WOT.
X2 guy i know worked on some b1 had similiar issues it was plugs and fuel selector was bad
Yes Idle is now steady and seems to be perfect. Only issues now are power. I just replaced my prop because the older one had rough edges. Wondering is its a cavitation problem. I will test today. I will also try new plugs.
