Kind of hard to describe without a picture but the straight edge should be square to both couplers.What do you do with the straight edge, could you give more detail?
Yes but then check to see if the coupler gap is the same everywhere.I think i know what you mean now, do you put the straight edge on top of the coupler running the same direction as drive shaft and the two couplers should sit flush with the straight edge?
If so i have just done this and my coupler on the engine side is slightly lower.
Do i need to shim up the back or the whole motor?
