- Largo, Fl
chit yea... bolt it up.
I am running the 14/19 big hub with pump stuffer.
I have an 11/17 hooker in my freak with a Dasa 850 with setback mag, it hits nice!
Good to know thanks...does your setup have enough power to 180 hop into a flip ? just wondering.
FYI: I could never figure this one out even with a 1l motor, TL, 148 pump. Not with the Freak anyways. Maybe I'm dumb though. That's the most likely cause.
I run a 10/16 w/144 mag and 850 SS. $$$$$
Personal opinion: The SF is such a great rec-riding boat that doesn't beat you up, but the downside is that it's not overly flip happy. Yes, it flips easy compared to a SJ - but not compared to other boats.
I feel like a BOB (G1 and G2) and Q8 flip a bit easier.
From what I've seen, KDX's and XFS's do, too.
Agreed on the Superfreaks not flipping so easy compared to those. Not from personal experience, just what I've scavenged from a local rider.
I think you kinda got the idea. Freak backends are wwwwwideeeee. Yes very stable. I don't think it has much to do with drag as opposed to trying to dig that backend into the water to ramp out a flip. I've only rode a freak a bit, but I know two owners who agree. Freaks like to float on the surface. A freak is harder to dig that back end into the water to get the launch it needs compared to other hulls. It can flip, but takes a bit more power than those that can dig in a bit better.
how much wider is the freak in the rear than some others mentioned here,that extra 45 degree bond rail drop prolly doesnt help either,Id like to ride one with the rail trimed up to see how well it would lean and rail corners
Setup wake flips are your best bet. Hop flips require considerably more power. I had trouble hop flipping my freak with an 1100, but really didn't have it figured out either. I'm not a great rider, but I can slide, hop, or wake flip my KDX. Same rules still apply. Wake flips are easiest flip wise, but require skill and timing to execute.
