Super Jet Superjet pump install
Hey guys I removed my pump so I could sharpen the impeller blades and plumb it for dual cooling. Now when I try to reinstall it the splines line up in the midshaft, but i still have about an inch to go before the pump bolts line up. Am I doing something wrong here? It was tight when I removed it. I am thinking the nubs on the wear ring are preventing it from lining up in the midshaft correctly.
Crab
thanks darin...noswad!
Seattle
rotate the splines a little and try again, sometimes worn splines need to go back in the same place...
