WaveDemon
Not Dead - Notable Member
- Hell, Florida
my truf isn't much longer for this world. I was thinking about fixing my wavy tray when I returf. what's a good long term fix?
it's not flatwavy tray?
i dunno, this is a 98 roundie. i assume that it had wet foam once and warped the tray.wasn't that a problem in the early squares?
it's not flat
you should fix the scratches under ur pump shoe while youre at it.
i never thought of that. thought water came in through bulkhead tubes, top/bottom deck seam, and the OEM foam holes
thats what Ollie said about you too.
That part was a joke. :banghead:ok, the least painfull option is body filler and a new layer of glass. Mark wins.
I'm not taking it down now. just a thought since I'll need turf soon. I may just leave it.Don't leave it if it's an air pocket. You don't need a 150-220lb rider bouncing up and down on an unsupported sheet of quarter inch fiberglass.
Don't you sluts ever ride? What's with all the skis going down voluntarily? :dunno:
