Super Jet B pipe install question
Was wondering if I can get some if any advice when installing. I was told to use an OEM gasket opposed to the one factory provided. Is that for true ? Everything else is stock. Its a mod pipe
ImageUploadedByTapatalk1361885190.521313.jpgImageUploadedByTapatalk1361885206.921175.jpg
Stock gasket is ok, single cooling is ok.. put all that in and concentrate on the barrel rolls :)
Btw you need to re-jet your carbs, did you do that?
the stock used one i ripped off or the new factory pipe one?? Did not re-jet. Kevin at leg drag will :)
The new one that comes with the pipe, its all good. Btw Andrew has mod chamber I have limited chamber, they felt the same as far as power band when we compared them on both SuperJets. Whoever feels the difference must be some power band guru like many here :))..
Was told for modded more definitely get the mod. For stock setup limited suppose to hit harder but kevin said he will make the mod hit the same. Either way i cant wait!
SkiDiggity
formerly kawirider142
Are you running a stock prop? If so i recommend ditching it and getting a solas big hub or a hooker :) I have the limited chamber on my set ups and it hits pretty hard, but i have never run a mod with out being on a heavily modded ski haha Would love to hear how it runs!!
Running a solas Concorde 13/17. Will keep you posted!
Having issue with the 2 middle bolts. They seem to bottom out before they can tighten the manifold.. The washers sit loosely in there. Are different bolts suppose to be used? I'm using the 8 oem ones I took off..
ImageUploadedByTapatalk1362057219.767615.jpgImageUploadedByTapatalk1362057252.867040.jpg
FlightPlanDan
Don'tTrustAfartAfter50
Kevin hooked me up with a b-pipe or two. Mod chambers on stock motors. (a while ago). Dealing with him was a good thing! He answered questions and made good suggestions b4 and after the sale.
IMO: always use new gaskets if you've got 'em.
