Superjetjim
X-
Does anyone have a picture of these installed please? Looks like they mount inside the bond rail, but are they flat plates/fins or do they have an angle/taper?
The fins mounted don't do much of anything, so we started experimenting with these blocks in varying forms and shapes. The JAM Raving sponsons completely change how a blaster turns. It probably makes more difference than any handling component ever made for the blaster.
SM
The NYNJA ones will allow you to lean more than the ones in the pic for sure, but just remember, the mod hulls will cavitate more than a stock hull if you lean it too far. We have a mod hull with a triple in it with NYNJAs and it turns like it is on rails.
Ski looks good! Isn't that the one the guy over in England built?
SM
Thanks for the clarity Scott.
Yes the ski is UK based (1 of 2 that made it over here) and is owned/rebuilt by me recently. The second one has now left the UK and is owned by 3rid on here and lives in the Netherlands.A
XJCrawler,
Handling is such a funny thing. What is perfect for one person sucks for another. SuperjetJim is a perfect example. His riding style might not agree with the NYNJA sponsons. Doesn't mean he is wrong or they are, just everyone has a different idea of what is the perfect set up.
I like my skis extremely abrupt in terms of handling. My brother doesn't like how my skis are set up, he says they are too twitchy. Again, to each his or her own.
But, for ME, I prefer the Jam Sponsons (the race versions - longer) a worx intake and a pro tec ride plate. I also true my hulls. The ride plate to hull mating service is extremely important as well. A lot of the aftermarket ride plates bolt up fine, but have a tendency to hang slightly below the hull, creating a negative step. Usually skis with these mismatched plates ride with a list to one side or the other. Basically, when you bolt up the plate, take a straight edge and make sure there isn't a step from the hull to the plate. If there is, best thing to do is to machine the top side of the plate so it can sit up a little higher.
Little things mean a ton of difference on a blaster. Good luck.
SM
