Custom/Hybrid WDK ROK-R 927 66E Based Build up!
WDK ROK R hull
927 66E Based Engine, with 1200R 66V big bore cylinder with WDK girdled head kit 87mm Wiseco
WDK billet PVs
WDK Pipe
WDK billet front cover
WDK billet intake upright manifold
66E upright kit
148 SB mag pump
Still deciding on Pole, Trim, Steering system, Carbs etc.
Looking for a set of FS49s.
Pics coming!
KTM434
Jamie FN Hickey
Palm Coast FL
Will this ski backflip with you in the tray?
BTW I think a competition length XM pole would be best for price, length, and flow on that ski
yamanube
This Is The Way
Staff member
Mandalor
Wet pipe? If so don't use standard cooling fittings for the water injection on your manifold, use spray fittings.
Chuck at CPT!
Picked up an Advent T4! Cant wait for that to arrive!
Yet, still debating on MSD TL VS T4... but couldn't pass up the T4!
Flywheel heading for some love at #ZERO!
Opinons on Scuppers?
Also deciding between using the quick disconnect system with the waterlines/pump like Jeff does, or going traditional
And if quick disconnect... need more info on them!
KTM434
Jamie FN Hickey
Palm Coast FL
It's a hard theory to grasp but I think they disconnect more quickly ;)
Scuppers: I have an Xmetal scupper that seems to work well. I have no foam and it hasn't sunk yet. I like the design of the epic scuppers with the magnet. Steve runs them on the Visions. I heard that Flipsides magnet was rusting since he rides surf but Steve had a post saying that they had updated the magnet to overcome this problem.
Chris's 66e getting a little timing change before the port job.....
Got the motor in, shimmed it up.
Got on the manifolds.
the whole Engine bay layed out today! Ordered up all the hose I will need.
Rad Dudes Todd came by and got the pump shoe looking PERFECT and lining up PERFECT.
Was pretty stoked that the water box fit!
Of course some problems- The speed plate broke... So having a new one made now!
Pump is due from Skat in about 2 more weeks!
Hull will be back from paint tomorrow, took forever to get the color in!
All the electronics heading to Mark at RadDudes for some wiring perfection!
