- Boynton Beach
Hey guys, I just wanted to share with all of you my excitement about my new Vision ski built by The Watercraft Factory. I am riding mostly surf down here in SE Florida, however I decided to go -4 length and have 2 ride plates: longer for the surf days and short for the flat days.
It is a glass version, fully reinforced inside with carbon fiber. The ski is 73.8 pounds dry weight on the hull and 11 pounds on the hood. This is the latest Vision model with 4" wider tray. I have ridden the Yellow Vision many times and find that hull very comfortable for all around ski.
Originally I was planning to use the ported 701 from my 2010 SJ, but I came across a good deal big bore 771 by Jetworks and went with it. Other than that: MSD enhancer, mag 12v 144mm pump, Vreeds, stock 38s duals, RRP pole/steering, B-pipe.
The ski will be at Daytona along with other Visions with different power plant setups and colors. Everyone will be welcome to stop by the Watercraft Factory crowd and check all these sweet skis out and may be test ride them .
Here is some shots:
Here is some shots:
