sxi steve
Life's short, have fun.
- Clinton Twp, MI
Engine
Tau Ceti Flame Arrestors
Primer Kit
Wiseco Pistons, bored over 1mm
Group K, Milled head, 170 psi
Moto Tassinari V-Force 3 reeds
R&D Advance Timing Plate
RAD Lightweight Charging Flywheel
Factory Limited Pipe (Wet)
Factory Pipe Waterbox (added 9-13-12)
Jet Works Water Control Valve
50:1 Fuel/Oil mix
Hull
Rule 500 gph bilge
Blowsion Tubby 2s
PLD Aftermarket Lightweight Aluminum Handlepole, -2 inches
JRE quick turnplate and straight bars, -1 inch
Odi Rogue Grips
Handlepole Limiter Rope
Blowsion Hyrdoturf Tray Mat and Padding
Dakine Foot Straps (attachment method: epoxy and welded corn nut/washer assembly)
Pump
R&D Aquavein/Top Loader Intake Grate
Worx Extended Ride Plate
Skat Trak 9-17 Swirl Impeller
Group K, Bored Nozzle
Short Pump Cone
Primer Kit
50:1 Fuel/Oil mix
Hull
Rule 500 gph bilge
Blowsion Tubby 2s
Odi Rogue Grips
Pump
Short Pump Cone
